  2. PSpice
  3. orcad pspice simulate error [ORPSIM-16015]
  • State Suggested Answer
  • Answers 1
  • Subscribers 33
  • Views 10747
sosokey
sosokey over 3 years ago
hi,
i start a project withh orcad pspice, gotta errors when i simulate with pspice, here is my error log:
  • TechiEE12
    TechiEE12 over 3 years ago +1
    Unknown parameter error may come due to multiple reasons like parameter incorrectly defined or there is a space in parameter value, e.g. 1K is written as 1 K as value for resistor. Since just from the…
  • oldmouldy
    oldmouldy over 3 years ago +1
    The Value field for the schematic parts should be "just that" to simulate. You can see that the parts that have only a value are accepted but the parts that have "<value> 50V" are not accepted since the…
  • sosokey
    sosokey over 3 years ago in reply to TechiEE12 +1 suggested
    hi, i follow your advice, but gotta errors
  • TechiEE12
    0 TechiEE12 over 3 years ago
    Since just from the .out file I cannot confirm the exact reason for this error.  We may need some more data hence will be contacting you through separate channel of communication.
  • oldmouldy
    0 oldmouldy over 3 years ago
    The Value field for the schematic parts should be "just that" to simulate. You can see that the parts that have only a value are accepted but the parts that have "<value> 50V" are not accepted since the simulator has no idea how to process 50V in the Part Value.
  • sosokey
    0 sosokey over 3 years ago in reply to TechiEE12
    hi,
  • oldmouldy
    0 oldmouldy over 3 years ago in reply to sosokey
    Since the space character is a delimiter, "10K" is a value but "10 K" is 10 and "something else" which get interpreted as a parameter that isn't valid.
  • HIMS
    0 HIMS over 2 years ago in reply to sosokey
    Try giving temperature coefficients separately, i.e, TC1=0 TC2=0.
