  2. PSpice
  3. Orcad Pspice menu bar
  • Subscribers 32
  • Views 8718
coulonnus
coulonnus over 3 years ago
I work with Orcad pspice demo version release 9. I moved the menu bar out of the pspice window and I quit pspice. Now the menu bar has disappeared. How can I recover it?
  • Andrew018
    0 Andrew018 over 3 years ago
    To recover the menu bar in OrCAD PSpice Demo Version Release 9, follow these steps:
    1. Open OrCAD PSpice.
    2. Click on the View menu.
    3. Select Toolbars.
    4. Check the box next to Menu Bar.
    5. Click on Close.
    The menu bar should now be restored.
    If the menu bar is still not visible, you can try restarting OrCAD PSpice.
    Here are some other things you can try:
    • Make sure that you are using the latest version of OrCAD PSpice.
    • Check the settings in your Windows display. Make sure that the menu bar is not hidden.
    • Try changing the resolution of your monitor.
    • If you are using a dual monitor setup, make sure that the menu bar is not being displayed on the second monitor.
      Also, check out AC Football Cases.
  • coulonnus
    0 coulonnus over 3 years ago in reply to Andrew018
    The problem is that most menus have disappeared! The only icons I see are New, new simulation profile, Open, diskette, print, Always on top, view circuit file, view output file, simulation queue, edit simulation settings.
    Can you attach an image showing where to click please?
  • coulonnus
    0 coulonnus over 3 years ago in reply to coulonnus
    A
    On another computer, above the icons I named are these icons: File View Simulation Tools Window Help. But here they have disappeared. On the other computer the  View icon gives access to what you said.
