  2. PSpice
  3. WARNING(ORNET-1119): No PSpiceTemplate for U4, ignoring
  • Subscribers 32
  • Views 2814
meadow
meadow over 3 years ago
I am encountering an issue with my charge amplifier simulation, as it is not functioning correctly. I am receiving the following warning message:
'WARNING(ORNET-1119): No PSpiceTemplate for U4, ignoring'
Additionally, when I open the simulation window, it displays an error like this
I am using Pspice orcad 16.6 (cis lite)
here is my circuit
thank you
  • oldmouldy
    0 oldmouldy over 3 years ago
    The screen shot shows U5 in the circuit but I suspect that the problem is related to the same issue. The part has been placed from the "schematic" libraries, <install path>\tools\Capture\Library and not from the "PSpice" libraries, <install path>\tools\Capture\Library\PSpice and the required PSpice Template property is therefore missing. This property links the path in the schematic with the PSpice Model and, since there isn't a link to a Model, the Nodes are floating - don't have a path to the 0 Node.
