  2. PSpice
  3. Monte Carlo analysis takes into account different model...
  • State Verified Answer
  • Subscribers 31
  • Views 5953
Monte Carlo analysis takes into account different model parameters (Bv, Is...)?
MujikaJulen
MujikaJulen over 3 years ago
While doing the Monte Carlo analysis, is there a way to know if model parameters such as saturation current, reverse breakdown voltage and much more, are being taken into account? Or does it only affect to established tolerances in R,L,C...?
  • AyushD
    AyushD over 3 years ago +1 verified
    The Monte Carlo analysis calculates the circuit response to changes in part values by randomly varying all of the model parameters for which a tolerance is specified. This provides statistical data on…
  • AyushD
    AyushD over 3 years ago in reply to MujikaJulen +1
    This is what i tried And same can be seen in the mcp file as below after running MC Regards, Ayush
  • AyushD
    +1 AyushD over 3 years ago
    The Monte Carlo analysis calculates the circuit response to changes in part values by randomly varying all of the model parameters for which a tolerance is specified. This provides statistical data on the impact of a device parameter’s variance.
    So for example if you have defined tolerance on saturation current of a transistor (Is) it will vary its value within the defined range randomly while performing analysis.
  • MujikaJulen
    0 MujikaJulen over 3 years ago in reply to AyushD
    Okay, thanks. But how would you define tolerance for model parameters? I haven't found a way to do it yet.
  • AyushD
    0 AyushD over 3 years ago in reply to MujikaJulen
    Ayush
  • MujikaJulen
    It's really useful, thanks!
