Home
  • Products
  • Solutions
  • Support
  • Company
This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
  • Products
  • Solutions
  • Support
  • Company
Community PCB Design & IC Packaging (Allegro X) PSpice Voltage doubler Capacitance values
  • Subscribers 26
  • Views 3980
jmakwana
jmakwana over 1 year ago
I have an astable multivibrator that produces 5v square wave input to the push-pull and the voltage doubler part of the circuit. Now somehow the simulation works at 0.1uF capacitors for the voltage doubler, but I do not understand how to select the values for the capacitor when I have an input at 32.3kHz.my max current load will be 60mA. I am essentially building this to power Opampms in my circuit....OPA4140
I have the screenshot in a zip file too if you cant see via the link
  • jmakwana
    0 jmakwana over 1 year ago
    Screenshot (1496).zip
  • retiredEE
    0 retiredEE over 1 year ago
    This circuit will not double the voltage but comes close if the load current is very low. Fast switching Shottky diodes are a must to keep their drops low and support the high surge currents through them. The input push-pull stage current drive and response time are also important. The following two equations can get you started estimating C3 and C4.
    Vout(Avg) = 10 - Vd1 - Vd2 - 60mA / (C3 x 32.3kHz)
    Vout(P-P ripple) = 60mA / (C4 x 32.3kHz)
