  2. PSpice
  3. PSpice derivative not smooth
  • State Verified Answer
  • Subscribers 31
  • Views 5831
BertRAMAerts
BertRAMAerts over 3 years ago
This is my circuit:
What I do not understand is the un-stability of the derivative:
I would expect a flat line...  What can be wrong
  • BertRAMAerts
    BertRAMAerts over 3 years ago +1
    Of course a derivative of 200K=200000 is huge, atan(200000)-Pi/2=5E-6 so very very close to Pi/2. Taking a much bigger max timestep of 0.5usec instead of 0.01usec gives a better result with much less noise…
  • BertRAMAerts
    BertRAMAerts over 3 years ago in reply to BertRAMAerts +1 verified
    It was just a setting: I made the relative tolerance 10 times smaller than the default value: and now the gain looks great even with very small timestep of 0.01 usec:
  • BertRAMAerts
    0 BertRAMAerts over 3 years ago
    Taking a much bigger max timestep of 0.5usec instead of 0.01usec gives a better result with much less noise.
    Not sure why...
  • BertRAMAerts
    +1 BertRAMAerts over 3 years ago in reply to BertRAMAerts
  • AyushD
    0 AyushD over 3 years ago in reply to BertRAMAerts
    You just tighten the accuracy and hence smooth line.
