  2. PSpice
  3. TI components missing from PSPICE for TI
  • State Suggested Answer
  • Replies 7
  • Answers 2
  • Subscribers 32
  • Views 11841
PaulGro
PaulGro over 3 years ago
I have installed Pspice for TI to run a simulation for a TI part TLV9021.
This part and many others are missing from the library and when I tried importing them I have broken my Cadence Pspice.
It now reboots every time I try to open my design file.
Can the TI parts be added to the Pspice for TI ??
Is it the same as importing 3rd party devices ?
  • retiredEE
    retiredEE over 2 years ago in reply to PaulGro +1 suggested
    Try a re-installation of the software. The version I'm using now is 17.4-2023 S009 and it does contain the TLV9022 part in its library.
  • retiredEE
    0 retiredEE over 2 years ago in reply to PaulGro
    What I meant is to re-install PSpice for TI.  I had a previous problem with the library installation and fixed it by a total re-install.  Have you tried posting this problem on the TI E2ETm design support forum?
  • MWMDMFB
    0 MWMDMFB over 2 years ago in reply to PaulGro
    For the issue with the greyed out "Generate Part" button the solution is to select the .dsn file (or any other part of the project apparently) before opening the Tools dropdrown.
    See TI forum post here:
    https://e2e.ti.com/support/tools/simulation-hardware-system-design-tools-group/sim-hw-system-design/f/simulation-hardware-system-design-tools-forum/983121/trouble-with-generate-part-function-in-pspice-for-ti
    <quote>
    Ethan,
    The tool needs to know where to put the generated symbol file. Please try to select a file in your project before clicking the menu, for example, you can select the dsn file.
    JC
    <\quote>
