  2. PSpice
  3. How to import ibis file into Pspice?
  • Replies 7
  • Subscribers 34
  • Views 10270
Darren AD
Darren AD over 2 years ago
I get ibis file form TI website named SN74LXC2T45, and would like to add it into Pspice, can anyone show how to import ibis file in Pspice?
    ShawnLogan over 2 years ago +1
    Dear Darren AD, Darren AD said: can anyone show how to import ibis file in Pspice? Did you happen to read the instructions in the following Forum post when you searched for a solution? https:/…
  • Darren AD
    Darren AD over 2 years ago in reply to ShawnLogan +1
    Dear Shawn I already read this post, and successfully transfer to another files (such as .lob, .olb, .dml, cir). But I got some errors after import .olb files. is there a instructrion that shows…
    ShawnLogan over 2 years ago in reply to Darren AD +1
    Dear Darren AD, Darren AD said: is there a instructrion that shows how to import TI files into Pspice? (by the way, I use Cadence Pspice tool, not PSpice for TI) I am afraid I don't know the answer…
  • Alok Tripathi
    Alok Tripathi over 2 years ago in reply to Darren AD
    IBIS files are only IO models and they do not include functional behavior of device. Unlike SPICE model the IBIS models lack functional part.
  • oldmouldy
    oldmouldy over 2 years ago in reply to Darren AD
    In the Model Editor IBIS Translator you can select the option for Create Stimulus for Output Models, that will get you a "standalone" version of the output model that will generate a waveform. SN74LXC245_io_3p2_typ for example. Place in a test circuit, terminate the pins with resistors and run a transient simulation for 1000ns to probe the output. As Alok says, IBIS only models the IO transfer and no internal functionality. You could take the SN74LXC245_io_3p2_typ, for example, text model and look at the VPULSE connection in the file, remove the VPULSE and "expose" the connection as a node and then generate a Capture Symbol from the modified model text to get the node as a Pin. Then that Pin could be driven in a Schematic to provide output with the IBIS transition. That would model the output characteristic  when driving but wouldn't model the tristate capability of the output buffer.
