  2. PSpice
  3. How to import ibis file into Pspice?
  • Replies 7
  • Subscribers 34
  • Views 10269
Darren AD
Darren AD over 2 years ago
I get ibis file form TI website named SN74LXC2T45, and would like to add it into Pspice, can anyone show how to import ibis file in Pspice?
    ShawnLogan over 2 years ago +1
    Dear Darren AD, Darren AD said: can anyone show how to import ibis file in Pspice? Did you happen to read the instructions in the following Forum post when you searched for a solution? https:/…
  • Darren AD
    Darren AD over 2 years ago in reply to ShawnLogan +1
    Dear Shawn I already read this post, and successfully transfer to another files (such as .lob, .olb, .dml, cir). But I got some errors after import .olb files. is there a instructrion that shows…
    ShawnLogan over 2 years ago in reply to Darren AD +1
    Dear Darren AD, Darren AD said: is there a instructrion that shows how to import TI files into Pspice? (by the way, I use Cadence Pspice tool, not PSpice for TI) I am afraid I don't know the answer…
    Dear Darren AD,
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pspice/54265/how-to-convert-ibis-models-into-pspice-model
    Shawn
  • Darren AD
    Dear Shawn
    The error messages shows below  after executing new simulation profile:
    ERROR(ORPSIM-15108): Subcircuit SN74LXC2T45_IO_5P0_TYP used by X_U3 is undefined
    ERROR(ORPSIM-15108): Subcircuit SN74LXC2T45_INPUT_3P3_TYP used by X_U4 is undefined
    Dear Darren AD,
    I am afraid I don't know the answer to your question - sorry!
    Shawn
  • oldmouldy
    oldmouldy over 2 years ago in reply to Darren AD
    Capture - PSpice simulation needs two libraries, the graphical OLB files to place the Parts in the Schematic and the LIB (text) files for the simulation models. It sounds like you haven't added the required LIB files for the translated models to the Simulation Profile, PSpice>Edit Simulation Profile>Configuration Files>Library, use the upper Browse to locate the required LIB file and then use Add To Design, for example, to add the LIB file. Repeat the steps for any additional LIB files.
  • Darren AD
    Darren AD over 2 years ago in reply to oldmouldy
    Thanks for your imformation.
    I suscessfully get simulation result after adding .lib file into library.
    But it looks like wrong value at U3_#2 and U5_#2.  Is this ibis file correct?
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/110/scem789-_2800_1_2900_.zip
