  2. PSpice
  3. PSPICE for TI - TPS2662x 60-V, 800-mA Industrial eFuse ...
  • Subscribers 31
  • Views 1881
PSPICE for TI - TPS2662x 60-V, 800-mA Industrial eFuse - OVP does not vary
Pete2
Pete2 over 2 years ago
checking up for the TPS2662x 60-V, 800-mA Industrial eFuse from TI all is working despite the upper voltage working limits.
The OVP limit is installed at 30V for all 5 parts instead of 38V only for the TPS26622/TPS26623 types.
Only the UVLO is changeable via resistor networks as described within the data sheet.
Is there a workaraound existing? Or has the modell to be updated?
Thanks a lot !          Pete2
  • AyushD
    0 AyushD over 2 years ago
    As per datasheet you can control the OVP externally using a resistor divider from input supply to OVP pin.
    Did you try connecting the resistor divider as required ?
  • Pete2
    0 Pete2 over 2 years ago in reply to AyushD
    Thank you for answer.
    Yes indeed this part is successfully used in my practical circuits at all. Now I tried to simulate this part for the higher up to 57 V voltages before integrating it into a new circuit this 3-resistor-divider implemented with the lower UVLO working giving a voltage ramp to the input referenced to GND.
    P.S.: It is also that many TPS power-management parts only function correctly referenced to GND 0 but not shifted to a higher level, eg. TPS3701..
