  2. PSpice
  3. How to assign different values to various components in...
  • State Verified Answer
  • Subscribers 31
  • Views 6605
How to assign different values to various components in Pspice
MujikaJulen
MujikaJulen over 2 years ago
Hey there! I'm curently working on converting a project from LTspice to Pspice. The problem is that I need to assign different values to a capacitor and resistor depending on the value of a variable "n". In LTspice I can use the command "TABLE" like in the shared photo. Does someone know how to make this work in Pspice too?
When n=0 -> Cload=8pF & Rload=750k
When n=1 -> Cload=290n & Rload= 1.3
  • retiredEE
    retiredEE over 2 years ago +1 verified
    Use the TABLE function in an expression for the components value. The parameter "n" can be used as an index into the tabulated list as is done in LTspice.
  • retiredEE
    retiredEE over 2 years ago in reply to MujikaJulen +1 verified
  • retiredEE
    +1 retiredEE over 2 years ago
  • MujikaJulen
    0 MujikaJulen over 2 years ago in reply to retiredEE
    But like using the TABLE part or do you mean there is a written way to code it?
  • retiredEE
    +1 retiredEE over 2 years ago in reply to MujikaJulen
  • MujikaJulen
    Thanks a lot!
