  2. PSpice
  3. Modeling a frequency dependent Inductor in PSpice
  • Subscribers 30
  • Views 5158
DesignTech
DesignTech over 2 years ago
You can now model a frequency-dependent inductor in PSpice in three simple steps:
  1. Extract data from the manufacturer datasheet.
  1. Convert the data into a csv file.
  1. Simulate in PSpice by using AC analysis.
To model the inductance, you will use the GFREQ_FILE component, which supports entries from a CSV file. This component has the following format as entries in a CSV file.
Frequency, Magnitude, Phase
You can extract the frequency vs. inductance data from the graph provided in the inductor’s datasheet and the magnitude can be calculated using the following formula:
1/(2*pi*f*L)
Phase for inductance is 90 degrees. Following are the CSV table entries with the magnitude derived using this equation. Save the CSV file on the disk.
Frequency
Magnitude
Phase
10k
0.04681028
90
100k
0.004822877
90
500k
0.000979415
90
600k
0.000808714
90
700k
0.000688982
90
800k
0.000598327
90
900k
0.000527877
90
1meg
0.000468103
90
1.5meg
0.000294731
90
2meg
0.000204045
90
2.5meg
0.000148051
90
3meg
0.000108269
90
3.5meg
0.0000798
90
Select the GFREQ_FILE component and open its properties to enter the location of your csv file against the FREQ_FILE property as shown below:
Create a circuit and using AC sweep analysis, you can plot the behavior.
Team DesignTech
Cadence Design Systems
