  2. PSpice
  3. How to use variable in pspice model editor?
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 5645
YunYeong Choi
YunYeong Choi over 2 years ago
Hello. I'm using pspice model editor. I know that the Pspice model editor can change the model parameter through the model test. I want to set my own variables in the model test and put it into the model parameter.
For example, I want to define EG using two variables (a, b).
a = 3*4
b = a-10
EG = b-0.2
 Although I can combine two variables into one like EG = {{{a}-10}-0.2}, I want to define variables more than two.
  • TechiEE12
    TechiEE12 over 2 years ago +1 suggested
    Hello Yes you can define multiple variables and use them in a single expression. It is my understanding you want the simulator to read the values of params from the model definition and no param is defined…
  • TechiEE12
    0 TechiEE12 over 2 years ago
    Hello
    Yes you can define multiple variables and use them in a single expression. It is my understanding you want the simulator to read the values of params from the model definition and no param is defined on canvas or device property in the schematic.
    Here is a working sample of a subckt definition that I tried at my end. You may need to modify your syntax.
    Hope this helps.
