  2. PSpice
  3. Difference between the IBIS file and LIB file
  • State Suggested Answer
  • Answers 1
  • Subscribers 32
  • Views 4492
RohitRohan
RohitRohan over 2 years ago
What is the difference between the IBIS file and the LIB file which is most preferable from the OEM and which has better results like which gives better accuracy.
  • oldmouldy
    oldmouldy over 2 years ago +2 suggested
    IBIS is a standard, IBIS - I/O Buffer Information Specification, and provides a model of the I/O buffers of a device. A LIB file could be "anything" but, from a PSpice perspective, represents the functional…
  • oldmouldy
    0 oldmouldy over 2 years ago
    IBIS is a standard, IBIS - I/O Buffer Information Specification, and provides a model of the I/O buffers of a device. A LIB file could be "anything" but, from a PSpice perspective, represents the functional behavior of a device in a format that the simulator can use - for IP protection reasons, the LIB file contents may be encrypted, or may only model "some" of the functionality of the device. IBIS models may provide more accuracy as far as the I/O behavior of the model is concerned but they provide no functional behavior whatsoever.
    • Vote Up +2 Vote Down
