  2. PSpice
  3. MonteCarlo parameters can't be written in the .mcp file
  • State Verified Answer
  • Subscribers 31
  • Views 2219
MujikaJulen
MujikaJulen over 2 years ago
Hey! There is an option in the MonteCarlo analysis configuration where you can decide if you want the schematic parameters to be saved in a .mcp file. When I try to simulate a mc analysis with the "Save parameter values in file" with its respective route to be stored, i get the following message:
"Unable to weite output file C:/ ......... /X-PspiceFiles/SCHEMATIC1/MC2/MC2.mcp"
How can I solve this problem? I really need the parameter list for analytical purpouses.
  • AyushD
    AyushD over 2 years ago +1 verified
    Do you get any other message with this ? I think tool is unable to write at the given location. You can try selecting some other writable location on your system to save the mcp file and see if that…
  • AyushD
    +1 AyushD over 2 years ago
    I think tool is unable to write at the given location. You can try selecting some other writable location on your system to save the mcp file and see if that works.
    For e.g. try saving it in a file at Desktop or somewhere else
  • MujikaJulen
    0 MujikaJulen over 2 years ago in reply to AyushD
    Yes, the problem seemed to be that in the given direction there was some kind of permission problem. Now I routed it to be written in the desktop and I had no problem with it. The file is what I expected it to be. Thank you!
