  2. PSpice
  3. How to export simulation report for transient analysis data...
  • Subscribers 32
  • Views 4246
How to export simulation report for transient analysis data in PSpice A/D
AyushD
AyushD over 2 years ago
PSpice A/D has an easy-to-use feature to export the transient analysis report in HTML format to capture and analyze data.
You can generate the report by using Tools > Generate Report in the PSpice A/D window.
The HTML report displays the transient analysis data in the following template sections:
  • General Information
    • Simulation Data (.dat) File
    • Analysis Name
    • Circuit Name
    • Simulation Time
    • PSpice Version
  • Circuit Information
    • List of Nets
    • List of Devices
  • Simulation Data
    • Current Data
    • Voltage Data
    • Power Data
Try it out and let us know if it is useful.
Team DesignTech
Cadence Design Systems
  • AyushD
    AyushD over 2 years ago in reply to DelphaPG +2
    Is it happening on this particular design or on every design? Can you try it on any other sample design once to confirm if the issue is design specific. It seems to be working at my end with 23.1 HF 0…
  • DelphaPG
    DelphaPG over 2 years ago
    Now I have tried a lot to get this function to work in OrCAD X 23.1 and PSpice A/D. Everything updated to newest version, short file path, both with Chrome and Edge as default browser. And I have tried to run the program as Administrator. In the output window it writes
    "Generating report for C:\Work\inputprotection-PSpiceFiles\SCHEMATIC1\inputprotection\InputProtection.dat"
    "Generating InputProtection.html"
    However, nothing is happen and there are no InputProtection.html file placed in any of the folders. What wends wrong?
    BR Dennis
  • AyushD
    Which hotfix of 23.1 have you installed ?
  • DelphaPG
    DelphaPG over 2 years ago in reply to AyushD
    SPB:Hotfix:23.10.005~wint
  • AyushD
    It seems to be working at my end with 23.1 HF 05
    • Vote Up +2 Vote Down
  • DelphaPG
    I have tried with different inherited projects with the same problem. However, when I starts from a brand new and pure project it seems to work. I will see if the trouble comes back. Thanks so fare Thumbsup
