  2. PSpice
  3. Monte Carlo simulation automatically modifies component...
  • State Verified Answer
  • Subscribers 31
  • Views 3987
Monte Carlo simulation automatically modifies component tolerances?
Zhengzhi Wang
Zhengzhi Wang over 2 years ago
When performing Monte Carlo simulation to modify the tolerances of capacitors and resistors, I modified them manually.
For example: manually modify from 10% to 5%, and then run the simulation to see if the results meet the requirements.
Is there a way to automatically change the tolerance value from 1%, 5%, and 10%, and after the run is completed, I can observe the output simulation results in these situations at once.
Thank you very much!
  • TechiEE12
    TechiEE12 over 2 years ago +1 verified
    One way to achieve this could be running Pspice in batch mode. You will need to create multiple .cir files each dedicated to a tolerance value. In the batch file you can call these cir files one by one…
  • TechiEE12
    +1 TechiEE12 over 2 years ago
    One way to achieve this could be running Pspice in batch mode. You will need to create multiple .cir files each dedicated to a tolerance value. In the batch file you can call these cir files one by one.
    To run this, the "psp_cmd.exe" executable is called from the command line. This executable resides in the same location as 'pspice.exe'.
    Example: <CDS_INST_DIR>\tools\pspice\psp_cmd.exe -r <path to cir file>
    Hope this helps.
