  2. PSpice
  3. Can parameter sweep scan two global variables at the same...
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 5711
Can parameter sweep scan two global variables at the same time?
Zhengzhi Wang
Zhengzhi Wang over 2 years ago
Using the parameter scan function, can two variables be scanned at the same time?
For example, I need the values of capacitor and resistor to change within a certain range.
I observed the interface of the simulation configuration file and it seems that only one parameter can be set for scanning?
  • AyushD
    AyushD over 2 years ago +2 suggested
    No you can provide only one parameter name at a time in Parametric Sweep window. But what you can try is select DC Sweep from the Analysis Type Drop Down, there you will have option of Primary Sweep, Secondary…
  • AyushD
    AyushD over 2 years ago +1
    You can use Parametric Plotter from PSpice Advanced Analysis to sweep multiple variables at a time.
  • AyushD
    0 AyushD over 2 years ago
    But what you can try is select DC Sweep from the Analysis Type Drop Down, there you will have option of Primary Sweep, Secondary Sweep and Parametric sweep and in each tab you can select different global parameter if that helps.
    • Vote Up +2 Vote Down
  • AyushD
