  2. PSpice
  3. ERROR(ORPROBE-3133) When Measuring Slew Rate of MAX44284H...
  • Subscribers 31
  • Views 3199
ERROR(ORPROBE-3133) When Measuring Slew Rate of MAX44284H in PSPICE
WillChen072
WillChen072 over 2 years ago
I am currently testing the slew rate of the MAX44284H current-sense amplifier using PSPICE. When I use the "Evaluate Measurement" function to measure the falling edge slew rate (SlewRate_Fall(1)), I encounter the following error message:
ERROR(ORPROBE-3133): Measurement not evaluated due to Measurement search failure 1
How can I resolve this error to correctly measure the falling edge slew rate of the MAX44284H using the slewrate_Fall(1) function in the "Evaluate Measurement" tool? Are there any other settings or methods that could help solve this problem?Thank you for your assistance!
  • TechiEE12
    TechiEE12 over 2 years ago +2
    SlewRate_Fall function is used to calculate the slew rate of a negative going step response curve. You will need to pass the trace name as an argument here. The correct syntax is SlewRate_Fall(<trace name…
  • WillChen072
    WillChen072 over 2 years ago in reply to TechiEE12 +1
    I have attached an image of my circuit diagram for reference. The function I used is SlewRate_Fall(V(U2:OUT)). Additionally, I am unable to find models for Transphorm components on the PSPICE model library…
  • TechiEE12
    TechiEE12 over 2 years ago in reply to WillChen072 +1
    Can you also share the trace curve of V(U2:OUT). Hope it is a negative going response.
  • TechiEE12
    0 TechiEE12 over 2 years ago
    SlewRate_Fall function is used to calculate the slew rate of a negative going step response curve.  You will need to pass the trace name as an argument here. The correct syntax is SlewRate_Fall(<trace name>). Could you share the function with trace name that you are trying.
    • Vote Up +2 Vote Down
  • WillChen072
    0 WillChen072 over 2 years ago in reply to TechiEE12
    Additionally, I am unable to find models for Transphorm components on the PSPICE model library at www.pspice.com/.../transphorm. Are these models available elsewhere, or is there a specific reason they are not listed?
  • TechiEE12
    0 TechiEE12 over 2 years ago in reply to WillChen072
