  2. PSpice
  3. Issue with Falltime Measurement in PSpice - Discrepancy...
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 1942
Issue with Falltime Measurement in PSpice - Discrepancy between Simulated Waveform and Evaluate Measurement
WillChen072
WillChen072 over 2 years ago
I am encountering an issue with the Evaluate Measurement function in PSpice. Specifically, I am trying to measure the fall time (Falltime Noovershoot) of a waveform.
When I visually inspect the waveform, the fall time appears to be around 20 ns. However, the Evaluate Measurement tool reports a fall time of 2.5 µs, which is significantly different from what I observe.
Has anyone else experienced this discrepancy? Are there any known issues or settings that I might be overlooking which could cause such a large difference between the visual inspection and the measured value?
I appreciate any insights or suggestions you might have to resolve this issue.
Thank you!
  • AyushD
    AyushD over 2 years ago +1 suggested
    This function finds the difference between the X values where the trace first crosses 90% and then 10% of its maximum value with a negative slope. i.e. Find the falltime of a signal with no overshoot.…
  • AyushD
    0 AyushD over 2 years ago
    If the signal has overshoot, use Falltime_StepResponse()
