  2. PSpice
  3. VCVS and Laplace syntax
  • State Verified Answer
  • Subscribers 33
  • Views 6003
AB_1719507089133
AB_1719507089133 over 2 years ago
Very new to this forum and PSPCE.
I am trying to simulate a IRIAA input signal to a phono circuit.
I am using a VCVS, fed via VAC Sine source with Laplace output.
I am assignign the Laplace expression to the GAIN variable, as this appears to be the only way.
E_E1 10 0 N03563 N04684 Laplace
+ {V(10)}=(((s*.00318+1)*(s*.000075+1))/((s*.000318+1)))/10
My understanding is that the syntax for a VCVS in this case is:
E <(+) node> <(-) node> LAPLACE { } = + { }
But I don't believe that I have something configured right.
Very frustrated, thanks in advance.
  • retiredEE
    retiredEE over 2 years ago in reply to AB_1719507089133 +2 verified
    The format is: E<name> <(+) node> <(-) node> LAPLACE { <expression> } = { <transform> } Your RIAA transform must be enclosed in braces just like your expression.
  • retiredEE
    retiredEE over 2 years ago +1
    Use an ELAPLACE part from the abm.olb library. This is the RIAA recording characteristic curve that works for me. If needed, add a gain constant as required.
  • AB_1719507089133
    AB_1719507089133 over 2 years ago in reply to retiredEE +1
    I must have the syntax wrong as I had the transform and the part, but it still does not work. E_E1 10 0 N03563 0 Laplace + {V(10,0)}=(((s*.00318+1)*(s*.000075+1))/((s*.000318+1)))/10 ERROR MESSAGE…
  • retiredEE
    0 retiredEE over 2 years ago
  • AB_1719507089133
    0 AB_1719507089133 over 2 years ago in reply to retiredEE
    ERROR MESSAGE:
    ERROR(ORPSIM-16152): Invalid number: Error while converting token 'Laplace' to double value. Token can be a constant or expression
    Can someone tell me what I am doing wrong? Admittedly new to Pspice.
    Thank you in advance.
  • retiredEE
    +1 retiredEE over 2 years ago in reply to AB_1719507089133
    The format is:
    • Vote Up +2 Vote Down
  • AB_1719507089133
    Thank you very much. I was able to access Property Editor and from there it was no problem. Problem solved.
