  2. PSpice
  3. ERROR(ORPSIM-15113): Impossible tu use external library...
  • State Suggested Answer
  • Answers 1
  • Subscribers 32
  • Views 2090
ERROR(ORPSIM-15113): Impossible tu use external library from OSRAM fro pspice simulation
SimonFrancoisBe
SimonFrancoisBe over 2 years ago
Hello teams,
I am writing you about an error I get when I try to use external library from Osram.
I have associated the Pspice model to a standard diode in Capture. Then add the library in sim profile but I get error 15113.
I attach the lib file.
Thanks for your help,
Have a nice day,
Simon
  • AyushD
    AyushD over 2 years ago +2 suggested
    This error can also come if the model is defined as .subckt whereas the corresponding Capture part has the PSpiceTemplate property beginning with ' D ' (or any other device type) other than ' X '
  • AyushD
    0 AyushD over 2 years ago
    This error can also come if the model is defined as .subckt whereas the corresponding Capture part has the PSpiceTemplate property beginning with 'D' (or any other device type) other than 'X'
    • Vote Up +2 Vote Down
