  2. PSpice
  3. How to speed up PSpice Simulation Runs?
  • Subscribers 32
  • Views 4564
AyushD
AyushD over 2 years ago
SPB 23.1 release HF03 onward, PSpice Simulator provides support for parallel simulation to generate faster simulation results and to improve performance for the following analysis types:
  • Monte Carlo analysis
  • Parametric analysis
  • Temperature Sweep analysis
To enable parallel simulation runs, use the following options:
  • .OPTIONS ENABLE_PARALLEL_MONTECARLO for Monte Carlo analysis
  • .OPTIONS ENABLE_PARALLEL_PARAMSWEEP for Parametric analysis
  • .OPTIONS ENABLE_PARALLEL_TEMPSWEEP for Temperature Sweep analysis
You can also define the maximum number of parallel jobs to be completed in a simulation using the following syntax:
  • .OPTIONS MAX_PARALLEL_JOBS = <integer>
Note: The maximum number of parallel runs will depend on the available cores in your system.
Team DesignTech
Cadence Design Systems
