  2. PSpice
  3. How to create new PIN diode PSPICE model from datasheet
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 3160
Agupta
Agupta over 2 years ago
I want to create a PSPICE model for a specific PIN diode from it's datasheet, that does not have all the information required by the model editor to create an accurate model. Can someone please help me on how to do it for a datasheet that does not contain information about the following parameters:
XTI, FC, EG, BV, IBV, I, N, TT, etc.
  • AyushD
    AyushD over 2 years ago +1 suggested
    If the specific parameter values are not give in the datasheet you can also use the device characteristic curve method to create the model, if you have the required graphs in the datasheet. Else you…
  • AyushD
    0 AyushD over 2 years ago
    Else you can use the default values for those parameters and if you need to generate the exact model, you can as the manufacturer for the values of these parameters.
