  2. PSpice
  3. Correct "output variables" in "outputfile options" in "simulation...
  • Subscribers 31
  • Views 1888
Correct "output variables" in "outputfile options" in "simulation settings"
GB202410172855
GB202410172855 over 2 years ago
My first question, complete newbee...from Germany.
I simulated a gain clone amp with symmetric outputs with four LM1875 and I want to see the distortion of the symmetric amp.
Please, what is the correct expression to fill in in the field "output variables" in the "output file options" window in "simulation settings"?
Unfortunately I have no luck adding a picture "an error occurred...."
Thank you, Gerd
  • rg13
    rg13 over 2 years ago
    Gerd, I would suggest you to contact Cadence customer support to address your concerns regarding your project. You can create a support ticket with required files.
    For your question regarding Output file options and Output variables, you can refer the guide on Cadence online support in which everything is given in details:
    PSpice A/D User Guide -- Simulation examples
  • AyushD
    AyushD over 1 year ago
    If you are looking for Total Harmonic Distortion, you can check this video on youtube
    https://www.youtube.com/watch?v=ytXKLueWXHo
