  2. PSpice
  3. How to define measurement statements to get simulation output...
  • Subscribers 35
  • Views 5827
How to define measurement statements to get simulation output results in a textual format ?
AyushD
AyushD over 1 year ago
Allegro PSpice Simulator allows us to define measurement statements that can analyze simulation data of different analysis types and generate a text file with measurement data on the output simulation waveform.
You can use the `.MEAS` or `.MEASURE` command the `.MEAS`. The measurements are assigned to unique variables defined by the user, which can be invoked in other measurement expressions.
To use these measurements, you can create a new text file with the `.inc` extension and add the measurement commands.
Configure the file in the design simulation settings.
The measurement results will be generated as a text file inside the project folder after a successful simulation.
There are several types of measurements you can perform using the `.MEAS` command:
1. `TRIG...TARG`: Find the difference in the x-axis value (time/frequency/variable) when conditions are met (between the trigger point and the target point)
2. `FIND...WHEN`: Find the value of the argument when the specified condition is met.
3. `AVG, MIN, MAX, PP, RMS, MIN_AT, MAX_AT`: Calculate average, minimum, maximum, peak-to-peak, RMS, minimum at, and maximum at values.
4. `PARAM`: Measure a parametric expression defined in curly braces.
The general syntax for the `.MEAS` command is:
.MEASURE {DC|AC|TRAN} <measurement variable name>
Example: Find the average voltage of the node ‘out’ within a time interval of 1 ms to 1.2 ms.
.MEAS TRAN avg_out_vAVG V(out) FROM 1m TO 1.2m
Result: AVG_OUT_V: AVG(V(OUT))= 3.9711E+00 FROM 1.0000E-03 TO 1.2000E-03
  • ML202412179931
    ML202412179931 over 1 year ago
    To define measurement statements and obtain simulation output results in a textual format using Allegro PSpice Simulator, you use the .MEAS (or .MEASURE) command. This command allows you to define poki specific measurements on waveforms generated during simulations. To begin, you need to create a file with a .inc extension, which contains the measurement commands. This file is then included in your simulation setup. The general syntax for the .MEAS command is: .MEASURE {DC|AC|TRAN} <measurement_variable_name> <measurement_type> <measurement_target>, where {DC|AC|TRAN} specifies the type of analysis (DC, AC, or Transient), <measurement_variable_name> is the user-defined variable that stores the measurement result, <measurement_type> defines the type of measurement (such as AVG, MIN, MAX, RMS), and <measurement_target> indicates the signal or waveform to be measured. For example, to measure the average voltage of a node out over a time interval from 1ms to 1.2ms in a transient analysis, the command would be .MEASURE TRAN Avg_Voltage AVG V(out) FROM=1ms TO=1.2ms. After running the simulation, the measurement results will be saved in a text file within the project folder, which you can review.
    I hope this helps
  • JX202609134513
    JX202609134513 2 months ago in reply to ML202412179931
    I have tried the method you suggested. I added an .inc include file under Configuration Files in Cadence Capture CIS 17.4. This .inc file contains only one single line: .MEAS TRAN VOUT_at_5ms FIND V(VOUT) AT 5ms
    After running the simulation, I encountered an error message in the .out output file as shown below:
    【**** INCLUDING my_measure.inc ****
    ERROR(ORPSIM-16056): Unrecognizable command】
    I replaced .MEAS with .MEASURE, but the error remained unchanged. Could you please advise why this error occurs and how I can resolve it?
  • JX202609134513
    I have tried the method you suggested. I added an .inc include file under Configuration Files in Cadence Capture CIS 17.4. This .inc file contains only one single line: .MEAS TRAN VOUT_at_5ms FIND V(VOUT) AT=5ms
  • AyushD
    AyushD 1 month ago in reply to JX202609134513
    This feature is supported in 24.1 and later releases.
    Looks like you are using 17.4 hence the command is not recognised.
