  2. PSpice
  3. Simulation model running problem
  • State Verified Answer
  • Subscribers 31
  • Views 3380
LT20250201204
LT20250201204 over 1 year ago
Hello. I am new to PSpice and had some trouble setting up my simulation. I went double-checking the models and when testing the transformer from WE in provided screenshots, I recieved the following results. Models for LT and P are from separate files, but the LT model seems to be working properly since the primary-secondary turns ratio is 14.4:1. The simulation parameters in PSpice are set to match those seen in LT. Is there something I might've missed when setting up the simulation?
Thank you in advance,
Lenart
  • AyushD
    AyushD over 1 year ago +1
    Are you using the same LT Spice mdoel to simulate in PSpice as well ? Can you share the zipped testcase here so i can check it at my end and try to debug the same. If its confidential, i can contact you…
  • LT20250201204
    LT20250201204 over 1 year ago in reply to AyushD +1 verified
    Hello, when I was making a cleaner copy of the issue to send you, I ran the simulation just in case and this time it worked. I have no clue why it didn't work before. Just to clarify, the models were…
  • AyushD
    0 AyushD over 1 year ago
    If its confidential, i can contact you via mail separately for you to share the testcase.
  • LT20250201204
    +1 LT20250201204 over 1 year ago in reply to AyushD
    when I was making a cleaner copy of the issue to send you, I ran the simulation just in case and this time it worked. I have no clue why it didn't work before. Just to clarify, the models were both provided by WE for LT and P respectively, and when I checked the models in notepad they were the same. I have no clue why it wouldn't work before, but this seemed to fix my issue.
    Thank you regardless,
    Lenart
