  2. PSpice
  3. Obtain .olb file
  • State Verified Answer
  • Subscribers 31
  • Views 5752
Obtain .olb file
KD202502275710
KD202502275710 over 1 year ago
How can I obtain the .olb file for the GS-065-060-5-T-A model in OrCAD Capture PSpice if only the .lib file is available?
  • rg13
    rg13 over 1 year ago +1 verified
    If you have pspice library file .lib with you and want to create Orcad Capture symbol/part for it to utilize it on Capture schematic to perform simulation, you can use model editor for it. From the File…
  • rg13
    +1 rg13 over 1 year ago
    If you have pspice library file .lib with you and want to create Orcad Capture symbol/part for it to utilize it on Capture schematic to perform simulation, you can use model editor for it. From the File menu, choose Export to Capture Part Library.
    For more information on it, you can refer following article link:
    Article (20467340) Title: Usage of Custom Vendor Models in PSpice
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to rg13
    Thank you. This is partially helpful because I am unable to refer to the article. I dont have relevant keys to access the response.. Is there a way you can copy paste th earticle  so that O cud look into it. Thank you again.
  • HIMS
    0 HIMS over 1 year ago in reply to KD202502275710
    You can refer to this video
    www.youtube.com/watch
