  2. PSpice
  3. Share Insights : Waveform Analysis
  • Subscribers 32
  • Views 5497
PCBTech
PCBTech over 1 year ago
Which different methods can be used to measure the average value of a sinusoidal waveform in PSpice?
  • RohitRohan
    0 RohitRohan over 1 year ago
    Hai PCBTech,
    In the PSpice Simulation window, you can go to trace >> Add Trace >> Under Functions or Macros select the dropdown and select Analog Operator and Functions.
    Then Select "AVG()" and in the Left Hand Side, select the Simulation Output Variable and click on OK.
    Above is one method, another is using the .MEASURE command.
    Rohit Rohan
  • PCBTech
    0 PCBTech over 1 year ago in reply to RohitRohan
    Thanks for sharing your insights Rohit !!
    Can you share an example highlighting how you used .MEASURE command.
