  2. PSpice
  3. TI SPICE reports "File is read only or used"
  • State Verified Answer
  • Answers 1
  • Subscribers 32
  • Views 3096
FL20250929850
FL20250929850 over 1 year ago
I am using TI SPICE and try to run a simulation which works for the initial downloaded TI package (TL431). I can start the simulation as it it was provided by TI download.
But I can not save or change the simulation profile or schematic: Message is following
- tran is read only: can not update
- schematic is read only
In general it seems that the whole project is read only.
How can I change it from read only to editable?
  • IshaS
    IshaS over 1 year ago +1 verified
    Hi, Can you try copying the project to your local directory and then re-check. Example copy the project to C:\Users\<YourUsername>\Documents\ and then try to re-open. Also, can you right click…
  • IshaS
    +1 IshaS over 1 year ago
    Also, can you right click the project and select properties, there do you find read-only box checked?
  • FL20250929850
    0 FL20250929850 over 1 year ago in reply to IshaS
    right clicking the project and selecting the properties and updating (deactivate) "read-only" box did the trick. I can change and update now.
    Thanks a lot for the good and fast help.
    Franz
