  2. PSpice
  3. Measurement Syntax - Failing Simulation
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 2660
WM202510282226
WM202510282226 over 1 year ago
I am wanting to find the time at which when the difference between two voltages is less than a specified value.
My initial take (below) was this using google AI, but that doesn't work, and I find the documentation exceptionally unhelpful. At least for Orcad 17.2.
.MEAS TRAN res4 FIND time WHEN V(Vin)-V(Vb)=0.62
This looks LTspice like, so I imagine it's getting confused. I am running a monte-carlo, so I would like the command to be run each and every time there is a simulation run. So, if there are 100 runs, then there should be 100 data points of a time being given.
  • IshaS
    IshaS over 1 year ago in reply to WM202510282226 +1 suggested
    Hi Can you try .MEAS TRAN res4 FIND time WHEN V(Vin)={0.62+V(Vb)}
  • IshaS
    0 IshaS over 1 year ago
    So as per my understanding you are trying example: Va - vb < 5
     Can you try .meas abc when V(a) = {V(b) + 5} cross 1
    It will tell when Va will be equal to V(b) + 5 - so time before this can be considered where V(a) < V(b) + 5
    Please share your insights how it goes at your end.
  • WM202510282226
    0 WM202510282226 over 1 year ago in reply to IshaS
    No, that is not what I am wanting.
    I am wanting to record the time when Vin - Vb =< 0.62.
    I am running a monte carlo, so each run needs to be stored in a variable that gets recorded. Ltspice does it simply with the command I wrote originally.
  • IshaS
    0 IshaS over 1 year ago in reply to WM202510282226
    Hi
    Can you try
