  2. PSpice
  3. Hi Pspice team, I am getting the follwoing error even after...
  • State Suggested Answer
  • Answers 1
  • Subscribers 32
  • Views 2014
Hi Pspice team, I am getting the follwoing error even after configuration files added.
SK202602095340
SK202602095340 9 months ago
How to fix this error.
INFO(ORCAP-2191): Creating PSpice Netlist
INFO(ORNET-1041): Writing PSpice Flat Netlist c:\cadence\spb_23.1\tools\pspice\user_lib\lm741-pspicefiles\lm741_test-PSpiceFiles\SCHEMATIC1\SCHEMATIC1.net
INFO(ORNET-1169): Unable to open the property mapping file: C:\Cadence\SPB_23.1\tools\PSpice\Librarydevparam.txt. To resolve this problem, ensure that PSpice.ini exists at the correct location. After that check Library Path in simulation settings contains <installation-path>/tools/pspice/library path and then create the netlist again.
INFO(ORNET-1162): Unable to create design property file.
  • IshaS
    IshaS 9 months ago +1 suggested
    Are you getting this error with every PSpice design files? Can you try renaming cdssetup folder to cdssetup_old present at your home location (%HOME%) Try to create a new PSpice project and then check…
  • IshaS
    0 IshaS 9 months ago
    Try to create a new PSpice project and then check.
    Share your observations how it goes at your end.
