  2. PSpice
  3. OP467 Component - Simulation Model Issue
  • Subscribers 31
  • Views 1522
MrTF
MrTF 7 months ago
Dear all,
I am using the OP467 model, which I selected via (Menu)
Place → Component → PSpice Category Model.
During simulation, I receive the following warning:
DRC Type: Electrical
Warning (ORCAP‑2445)
Instance UxD, SCHEMATIC1, PAGE 1 (XXX.xx, XXX.xx),
not found in the configured libraries.
Could someone please clarify:
  1. What exactly does this warning refer to?
  2. Does it imply any potential malfunction or inaccuracy in the simulation results?
  3. Why is the component reported as “not found in the configured libraries,” even though it appears to be located under the CIS Unified Library?
  4. In the model I use there is a parameter with the description "LEVEL 3". To what this parameter refers to?
Any guidance would be greatly appreciated.
Thank you in advance.
  • AyushD
    0 AyushD 7 months ago
    Are you getting this error in Online DRC ?
    Do you get any such error / message in .out file of the PSpice simulation.
    Is the simulation run successful ?
  • MrTF
    0 MrTF 7 months ago in reply to AyushD
    Dear AyushD.
    Yes, the warning appears on the "Online DRCs" tab,
    Spice simulation is completed without any warnings but I cannot say if it is successful or not if the model is not properly inferred by the simulation engine.
