  2. PSpice
  3. PSpice Special Component: Watch1
  • Subscribers 31
  • Views 548
AyushD
AyushD 5 months ago
.WATCH command enables user to observe voltage at node in simulation status windows while simulation is in progress.
Attach this part (WATCH1) at node or net which you will like to observe during the simulation. After this, you need to define following three parameters on symbol instance:
Analysis: Assign the one of the following three values depending upon the type of analysis being performed:
   DC
   AC
   TRAN
HI: Assign a numeric value to define upper limit of voltage
LO: Assign a numeric value to define lower limit of voltage
Simulator pauses if voltage at node is outside of range defined by HI and LO.
