  2. PSpice
  3. Persistent netlisting error
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 984
AG202606016357
AG202606016357 5 months ago
I'm using "PSpice for TI" to simulate a DCDC converter implementing a specific TI PWM controller (hence the selection of the simulation tool).
My schematic is drawn and seems correct. Still, when I launch the netlist generation, I get the following error message:
"ERROR(ORCAP-15065): There are netlisting errors.
Check the session log."
In the session log, I find:
"INFO(ORNET-1041): Writing PSpice Flat Netlist \\xxx\yyy\SCHEMATIC1\SCHEMATIC1.net
INFO(ORNET-1169): Unable to open the property mapping file: devparam.txt. To resolve this problem, ensure that PSpice.ini exists at the correct location. After that check Library Path in simulation settings contains <installation-path>/tools/pspice/library path and then create the netlist again.
INFO(ORNET-1162): Unable to create design property file"
I completed the proposed checks and everything is OK.
I gave a try with a very simple schematic (1 DC source, 1 ideal R and 1 ideal C). I got the exact same error.
How can I solve this error?
What should I do?
Thanks for helping me.
  • IshaS
    IshaS 5 months ago +1 suggested
    Hi AG202606016357 , Can you please try below: copy the attached devparam.txt file at the <cdns_ inst _dir>/tools/ pspice /library location. /cfs-file/__key/communityserver-discussions-components-files…
  • IshaS
    0 IshaS 5 months ago
    Hi AG202606016357,
    copy the attached devparam.txt file at the <cdns_inst_dir>/tools/pspice/library location.
    /cfs-file/__key/communityserver-discussions-components-files/110/devparam.txt
    Open your simulation settings:
    Check the library path in the Simulation Settings window as shown in the following snapshot. In Capture, go to PSpice > Edit simulation profile > Configuration Files > Library and check the Library Path value. It should point to <cdns_inst_dir>/tools/pspice/library.
    Try this and share your insights how it goes at your end.
