  2. PSpice
  3. PSPICE for TI installation
  • Subscribers 31
  • Views 645
FT202611041530
FT202611041530 23 days ago
Issue when installing "PSPICE for TI", I saw some posts on the same subject, is cadence working to resolve ?
The snapshot of the error and the log are attached below
Fullscreen cdsPSpiceNetworkStatus.txt Download
The PSpice for TI installer accesses the internet to download and install various packages. Before starting the installer, ensure the following:
	1.	Internet connection is available
	2.	Security protocol TLS 1.2 is enabled
	3.	Following endpoints or resource locations are accessible from the system:
		a.	https://pcb.cadence.com/startPages
		b.	https://software-dl.ti.com/pspice
		c.	https://cdsplicwc.cadence.com/chws
If proxy credentials are required to access the Internet, provide the same when requested by the installer.
11:23:26 mercredi 4 novembre 2026 : *****CONNECTION STATUS CHECK*****
11:23:26 mercredi 4 novembre 2026 : Internet Connection : Available (Passed)
11:23:26 mercredi 4 novembre 2026 : Security Protocol TLS 1.2: Available. If PSpice for TI installation fails, unblock TLS 1.2
11:23:27 mercredi 4 novembre 2026 : Proxy Test : Proxy Credentials not needed
11:23:27 mercredi 4 novembre 2026 : Unable to access the URL required for installation
11:23:27 mercredi 4 novembre 2026 : URL : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:23:27 mercredi 4 novembre 2026 : Error Message : Le serveur distant a retourné une erreur : (403) Interdit.
11:23:27 mercredi 4 novembre 2026 : Status Code: Forbidden
11:23:27 mercredi 4 novembre 2026 : Status Description : Forbidden
Fullscreen cdsPspiceTIlog.txt Download
11:23:26 mercredi 4 novembre 2026 : parameter count = 1
11:23:26 mercredi 4 novembre 2026 : -wrapper
11:23:26 mercredi 4 novembre 2026 : Module Name: TIPSpice.exe
11:23:26 mercredi 4 novembre 2026 : Server OS = False
11:23:26 mercredi 4 novembre 2026 : Operating system version : 10.0.0.0
11:23:26 mercredi 4 novembre 2026 : Checking for proxy
11:23:27 mercredi 4 novembre 2026 : Le serveur distant a retourné une erreur : (403) Interdit.
11:23:27 mercredi 4 novembre 2026 : Response error : Forbidden
11:23:27 mercredi 4 novembre 2026 : Checking if Licensing URL is accessible
11:23:27 mercredi 4 novembre 2026 : Initializing
11:23:27 mercredi 4 novembre 2026 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:23:27 mercredi 4 novembre 2026 : Exception occured while downloading file : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:23:27 mercredi 4 novembre 2026 : Response Description: Forbidden
11:23:27 mercredi 4 novembre 2026 : C:\Users\franc\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 0
11:23:27 mercredi 4 novembre 2026 : Error occured while downloading URL file
11:23:27 mercredi 4 novembre 2026 : Error Message: Le serveur distant a retourné une erreur : (403) Interdit.
11:23:27 mercredi 4 novembre 2026 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
URL: https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
Error code: Forbidden
Error Description: Forbidden
View log file for details at C:\Users\franc\AppData\Roaming\Cadence\PspiceTIInstall\cdsPspiceTIlog.txt
  • rg13
    0 rg13 15 days ago
    Yes, this issue is already being worked upon.
