  3. how to generate Reference designator as like Capture CIS...
  • Subscribers 28
  • Views 10671
how to generate Reference designator as like Capture CIS in system capture ??
kabalee
kabalee over 4 years ago
Hi everyone,
i am using System capture. i tried to use the Reference designator for the symbol  like start from U1,U2 for IC , For Resistor from R1,R2 and capacitor it should start  C1,C2..
but in system capture Reference Designator included Page number and other. instead of that i required as like capture CIS (17.2) even I tried using Edit--> Preference .it is not working .
Kindly guide any one. please
  • atishcdns
    0 atishcdns over 4 years ago
    Check the CDS_SITE on your system. In your SITE folder go to cdssetup\projmgr\site.cpm check if you have entries such as
    REF_DES_PATTERN '($PHYS_DES_PREFIX)($PAGE)[0-9](00)'
    REFDES_ALPHA_NUM 'UNIT_NUM'
    { REFDES_ALPHA_NUM 'FULL_ALPHA' }
    REFDES_PAGE_PADDING '2'
    REF_DES_PATTERN_FIX 'ON'
    Make a copy the site.cpm file and then delete the entries from site.cpm and save the file. Close System Capture and load your design again and you should be able to see the Ref Des as U1 U2 etc.
  • kabalee
    0 kabalee over 4 years ago in reply to atishcdns
    Thanks for your update. i ll explore it and update the feedback.
    but i complete all schematic based on UXXXX . if i follow and regenerate .. it might be work right ??
    where i can find CDS_SITE  .. it is in project folder or installed location ?? please update it
  • atishcdns
    0 atishcdns over 4 years ago in reply to kabalee
    I don't think that regenerate will work because tool will again regenerate the netlist based on the ref des pattern defined in the site.
