  3. Why to use Allegro System Capture – Hierarchical Varian...
  • Subscribers 26
  • Views 7410
Why to use Allegro System Capture – Hierarchical Variants
DesignTech
DesignTech over 3 years ago
Many a times, it is desired to use the lower-level variant information in hierarchical designs. System Capture supports reusing variants defined in the child schematic, in the top-level design.
Add the following directive in the <project>.cpm or site.cpm file to enable hierarchical variants:
START_BOMHDL
HIER_BOM_PROP '<property_name>'
END_BOMHDL
<property_name> is the custom property defined on the lower-level hierarchical block.
Enabling Hierarchical Variants
Now, when you create variants in the top-level design, you will see a dropdown list containing lower-level hierarchical block variants for the selected block.
Choosing Hierarchical Variants
Team DesignTech
Cadence Design Systems
  • Jacobye
    Jacobye over 1 year ago
    yes
