  2. Design Entry HDL
  3. Non-electrical symbol added in HDL?
  • State Suggested Answer
  • Answers 1
  • Subscribers 23
  • Views 8133
bbertiaux
bbertiaux over 2 years ago
Is there a method for adding a non-electrical symbol to an HDL schematic such that it gets passed on to board layout (Allegro). We are interested in getting tooling and non-plated holes into the layout in this way - especially in a manner where the IDX file that the mechanical engineer provides would be able to place the non-electrical symbol.
  • rg13
    0 rg13 over 2 years ago
    In order to create mechanical parts to be used in HDL-Allegro flow, you can use Part developer (PDV).
    A mechanical part with the correct footprint can be passed to the Allegro PCB Editor netlist by defining the CLASS property on it.
    To do this, use the following steps:
    1. Open the mechanical part in Part Developer.
    2. Select the package and go to the General tab.
    3. Set Class to MECHANICAL as shown below:
    1. Assign a PCB footprint to the mechanical part.
    2. Save the part.
    3. Open the design in DE-HDL and do File > Export Physical.
    4. Import the logic/netlist in the PCB Editor and you will have mechanical parts available for placement.
    You can also find these steps on Cadence online support portal using following link:
    support.cadence.com/.../ArticleAttachmentPortal
  • rg13
    Its been a while since you posted this query. Have you found any method to achieve your requirement so far? If yes, please share that.
