  3. How do you manage large pin count parts?
  • Subscribers 29
  • Views 5684
Krishnadas
Krishnadas over 2 years ago
When working with large pin count parts like processors, FPGAs, and DDRs, one of the challenges is the creation of schematic symbols. It becomes an exhaustive task especially when creating such large pin symbols from scratch. A librarian would need to segregate pins as per the functionality. Now, you might wonder:
  • If the schematic symbol needs to be a split symbol
  • How to manage power, ground, or unused pins
  • How to accommodate pins on the symbol so that it fits into the schematic page
How do you approach this?
  1. Split symbols with pins clubbed together based on functionality
  2. Separate symbols for power/ground sections
  3. A single symbol with all pins
  4. One large symbol with hidden or implicit power, ground, and NC pins
  5. Any other method
There might be other challenges that you may come across while working on parts with large pin counts. We look forward to hearing from your experience.
  • avant
    avant over 2 years ago
    Usually #1.
    NEVER #4. Power net names can change and leave unconnected pins. I want to see every symbol pin on a schematic.
  • shark0175
    shark0175 over 2 years ago
    In my experience, I often use the method of creating separate symbols for power/ground sections when dealing with large pin count parts. This helps in organizing and visually representing the functionality of the pins more effectively.
