  3. How to compare two schematic designs
  • Subscribers 26
  • Views 5905
Krishnadas
Krishnadas over 2 years ago
While working on a schematic, you make modifications to the design like importing sheets or copying circuitry from a reference design, and adding new interfaces, and create multiple versions of the design.
Sometimes, you might want to see the differences between the latest and a previous version of the design.
Doing a visual comparison is for sure a tedious and an error-prone task.
There are different ways of comparing designs. For example,
  1. Comparing netlist files
  2. Design comparison utilities
  3. Using custom scripts
  4. Comparing layouts
What is your preferred approach for design comparison?
We look forward to hearing from you.
  • RFinley
    RFinley over 2 years ago
    Cadence added design compare to Orcad Capture 17.4 under tools>
