  2. Adams Car
  3. Wheel offset?
  • Replies 10
  • Subscribers 1
  • Views 6
Wheel offset?
Jesper Slattengren
Jesper Slattengren over 9 years ago
So when I modify the tire/wheel, there is a field for wheel_offset. Which makes perfect sense. The wheel center is a design position on the intersection between the spin axis and the mating surface where the wheel is bolted on. On this design, different wheels can be used with different offsets. That will among other things change the scrub radius.
The problems are
  1. This parameter is not used by anything. Changing it does not move the tire in or out.
  2. Using the suspension testrig, there is nowhere to set this parameter. As this is using a testrig tire that does not expose this parameter. I can change it by manually search for this variable and change it. But it looks like an oversight. And it does not change the scrub radius or anything else in the simulation
OK, it is easy to fix for the full vehicle tire template, but it seems wrong to me.
Anyone else looked into this? @Martin Kieltsch​ you must have fixed this?
  • MK202610123211
    0 MK202610123211 over 9 years ago
    Concerning the variable set by the wheel modify dbox:
    .ACAR.macros.mac_tem_whe_smo is setting $wheel.center_offset
    That's only used in $wheel.geo_ctr which is (according to database navigator) which is only used by "$wheel.wheel_hub.cm"
    WheelHubInfo
    Just that there is no $wheel.wheel_hub.cm as wheel_hub is a cylinder and not a part.
    Without digging deeper, I simply assume
    that the intended behaviour was to move $wheel.cm and as a consequence it'd be bug.
  • Micha
    0 Micha over 9 years ago
    in FTire, we have wheel offset (=ET=Einpresstiefe, as Martin said) in the tire/rim data file. If this value is set, Adams is expected to give the location/motion of the *geometrical* center point of the rim as input to FTire; FTire takes into account the ET.
    If you prefer to handle wheel offset directly in your Adams model, this is no problem. In this case, you must set ET=0 in the tir-file (which obviously is the default).
    Very small disadvantage of the first method (ET set in the tir-file): you will not see the wheel offset in the Adams online animation. But you *will* see it in FTire's own animation window, and in the ogl-file-based offline animation in Adams/ PPT.
  • Jesper Slattengren
    0 Jesper Slattengren over 9 years ago
    @Martin Kieltsch​  the way you propose is the safe way as it would work with the suspension testrig wheel, but I hate to do it that way as the offset is a property of the wheel, not the suspension.
    Regarding your second answer: It seems like a big confusion from whoever created this template in the first place (likely not with MSC anymore) as there is a separate field for cm-offset compared to geometric offset. It seems like these two variables have been confused at some time.
  • greg.wheeler
    0 greg.wheeler over 9 years ago
    Jesper I'll create a defect on this.
    Thanks Greg.
