  2. Adams Car
  3. Solver Library for Driveline template from concept cdb
  • Subscribers 1
  • Views 10
GMatrang
GMatrang over 9 years ago
Good morning everyone,
I'm trying to run a model from command window that contains the driveline_awd template from the concept database.
The error that comes out is the following:
---- START: ERROR ----
Encountered error "No Library given and no default library for Varsub" while pro
cessing user subroutine for model.PP01_DrvlnAwd.rear_halfshaft_omega_left
---- END: ERROR ----
 command: !
 command: !INFO Adams Version: Adams 2017
 command: !INFO Adams Build:   2017.0.0-CL454846
 command: !INFO Solver Library: C:/MSC~1.SOF/Adams/2017/win64/acar_solver.dll
Am I missing something from the installation process of Adams?
Thanks in advance,
Giuseppe.
  • GMatrang
    0 GMatrang over 9 years ago
    Looking into the .bat file generated by a "background" analysis, I can read that the .acf is run by a different .exe:
    "C:\MSC~1.SOF\Adams\2017\runtime\win64\subacar.exe" ru-solver test_smart_driver.acf
    Do I need to run this command instead of calling the adams2017 ru-so?
    Giuseppe
  • Jesper Slattengren
    0 Jesper Slattengren over 9 years ago
    You must specify that you are running an ADAMS/Car model.
    I use the following command
    C:\MSC.Software\Adams\2017\common\mdi.bat acar ru-solver test_smart_driver.acf
    or actually, I have a bat file named acarsolv17.bat with the only line
    C:\MSC.Software\Adams\2017\common\mdi.bat acar ru-solver %1
    So I can run it with
    acarsolv17 test_smart_driver.acf
  • GMatrang
    Indeed, I've forgotten it.
    Many thanks.
  • MK202610123211
    0 MK202610123211 over 9 years ago
    Well if MSC had done their homework (i.e. added a routine statements to all usersub calls in their template) the A/view solver should have done the job.
