  2. Adams Car
  3. Correct procedure for saving post processing plots?
  • Subscribers 1
  • Views 0
mn14j3c
mn14j3c over 8 years ago
I am analysing data from tests of two different vehicles in adams car post processing window and comparing results on the same plot. When I exported the plot config file and opened it up again, I get duplicate results of each curves, meaning the legend contains several of the same data names.
What I am asking is, what is the correct way to save plots so that they can be accessed at a later date, to be edited and added to?
Thank you
  • MK202610123211
    0 MK202610123211 over 8 years ago
    To create the plot config file choose ONE analysis and create each curve you need ONCE.
    Then perform or read both analysis in question, read the plot-config file and choose "cross plotting".
    That'll use the plot-config file as a template and creates one curve for each analysis.
