  2. Adams Car
  3. Unable generate leaf spring using leaf spring editor in...
  • Subscribers 1
  • Views 3
Unable generate leaf spring using leaf spring editor in Adams/Car
Chaitanya
Chaitanya over 8 years ago
I am getting issue while generating leaf spring using Leaf editor in A/Car. I used example.ltf provided in acarshared database. Also used same hardpoints without any changes to default example ltf. Still I get error that " example.py is not created. Please review the leaf spring property file and try again." (Please see attachement)
Attached Files (1)
  • jozef.bucha
    0 jozef.bucha over 8 years ago
    Hello, i tried to generate leaf spring, using example.ltf in Adams 2018, without problem, it created leaf spring and also example.py in working dir.
    Do you have write access to working dir folder, or if i see Z: drive, is it local drive, not some mapped drive?
    Jozef
  • Chaitanya
    0 Chaitanya over 8 years ago
    Hi Jozef,
    Thanks for reply.
    You are right Z:drive is not local drive. When I change working directory to local drive, leaf gets generated without any problem.
    Chaitanya
