  2. Adams Car
  3. Tire/Rim ratio completely skewed
  • Subscribers 1
  • Views 1
aaditya.geed
aaditya.geed over 8 years ago
I was working with ADAMS Car using the FSAE 2018 template, and I imported my PAC2002 models for the Hoosier 16x10 LCO tire, but it resulted in the rim becoming extremely small.
a) Is there a way to differentiate the rim from the tire, if yes, how so?
b) If no, is there a way to define the rim spacing to its appropriate size?
Thank You
  • Jesper Slattengren
    0 Jesper Slattengren over 8 years ago
    You have the [DIMENSION] block in the tire property file. Change that.
    [DIMENSION]
     UNLOADED_RADIUS     = .6096
     WIDTH          = .389
     ASPECT_RATIO      = 1.0
  • aaditya.geed
    0 aaditya.geed over 8 years ago
    Yeah I had to change the aspect ratio, the tire that we were using had a pre-entered aspect ratio of 0.667, but when we measured it in person, it was closer to 0.5. Thanks for your help.
  • Alexis Del Rio
    0 Alexis Del Rio over 8 years ago
    Then I advice you to check that the tire property file is the correct one for your vehicle.
