  2. Adams Car
  3. CMD problem from A/Car 2017 to A/Car 2018
  • Replies 7
  • Subscribers 1
  • Views 2
jpatterson
jpatterson over 7 years ago
I have a cmd file I've used for many years to extract info about my A/Car suspension assemblies. It seems to be crashing now on the last line below in A/Car 2018 and I can't see why. Any thoughts...???
defaults function_references show_as = partial_name
!>>>>>> Capture model, analysis, and subsystem names...
var set var=Model_Name object=(eval(db_default(.system_defaults,"model")))
var set var=Analysis_Name object=(eval(db_default(.system_defaults,"analysis")))
var set var=Subsystem_Name string_value=(str_substr(eval(Model_Name.object_value[1]),1,(str_length(eval(Model_Name.object_value[1]))-1)))
var set var=Analysis_Subsystem_Name object=(eval(Analysis_Name.object_value)//eval(Subsystem_Name.string_value))
  • greg.wheeler
    0 greg.wheeler over 7 years ago
    Hi Jim. I don't know why it would crash. Did you get a .dmp file on crash? That might help us debug the code.
    But anyway, the expression looks a little odd to my eyes... I'd write it like this:
    var set var=Analysis_Subsystem_Name object=(eval(Analysis_Name//"."//Model_Name[1].name))
    the ".name" is a built-in way to get any object's name (not including any of its parents).
    And in general, you only need one eval() function per expression.
  • jpatterson
    0 jpatterson over 7 years ago
    Hi Greg,
    Sorry, that was poorly worded. By "crash" I meant I get an error on that line. If I run it as I always have I get...
    ERROR: ---------------------------------------------------------------------ERROR: Error detected on line number 9, character 112 of aaa.cmd.
    ERROR: Database object ".D27150_310_43pt5_77pt5_14RH_8HH_VS_C21800.SPD12210__Static_Load_Wheel_Center_Height.D27150_310_43pt5_77pt5_14RH_8HH_VS_C21800" does not exist
    ERROR: The command was not executed.
    ERROR: >> var set var=Analysis_Subsystem_Name object=(eval(Analysis_Name.object_value)//eval(Subsystem_Name.string_value))
    If I change it to your suggestion I get...
    ERROR: ---------------------------------------------------------------------ERROR: Error detected on line number 9, character 89 of aaa.cmd.
    ERROR: >> var set var=Analysis_Subsystem_Name object=(eval(Analysis_Name//"."//Model_Name[1].name))
    Weird it doubles up on the "ERROR: Database object" line...
  • greg.wheeler
    Aha. Did you verify that object does exist with that name?
    Notice my expression generated the same name as yours, so that's good...
  • jpatterson
    Found the problem. I'm a bonehead! I had a typo in my subsystem name...Persevere
    Always fun to find my dumb mistakes in a big group! Sunglasses
  • MK202610123211
    0 MK202610123211 over 7 years ago
    Some useful 0.02$ :
    Check out the function
    subsystem_lookup(db_default(.system_defaults,"model"),"suspension","rear")
    that returns the desired subsystem object.
    Usually much more elegant than building strings ....
    And another one:
    var set var=xxx can turn out ambiguous. It creates the variable under the default library/model and if you do that multiple times within a session, it's likely to create a var with the same name under different locations which will throw an error.
    I always create a full path/name like:
    library create library_name = .my_own_stuff
    var cre var = .my_own_stuff.my_unique_var
    If I'm lazy, I'm using existing libs like .acar:
    var cre var = .acar.my_unique_var
