  2. Adams Car
  3. How can I trigger an external action from within the driver...
  • Replies 9
  • Subscribers 1
  • Views 4
How can I trigger an external action from within the driver control file?
o.jonson
o.jonson over 6 years ago
I want to trigger an action from within the driver control files that is not an standard output (throttle/steering/clutch etc). Basically I want to do some minimaneuvers to achieve a certain vehicle state, then activate a parking lock torque in the gearbox, then deactivate it and continue the simulation.
Of course I could use some STEP(time) functions in the torque expression to activate the torque at the right moment, but that solution wouldn't be general for different driver control files . Any ideas on how to trigger such an action from within the driver control file?
/Oskar
  • r.gobbur
    0 r.gobbur over 6 years ago
    Another thought would be saving your runs files after attaining required state and performing activation/deactivation of torques of interest
    Then you can resume your run from that state
    You can help document from MSC simcompanion
    Hope this helps
  • o.jonson
    0 o.jonson over 6 years ago
    I'd like to avoid all solutions where manual editing of the .acf file done since all our simulations are automatically generated. My idea was (as Thomas mentioned) to try to get hold of the name of the minimanouver by calling some varsub routine. I could then match the manouver name (or id or something similar) from the variable , then latch some variables and step up a locking torque. This would avoid any manual work in the .acf files and would work for any driver control file.
    However if there is no routine that can get hold of this info from the driver control file, I guess the next best thing is to modify the .acf file with EventRunNext  and an activate command for the torque. Maybe I can call a script with the --pre command that rewrites the .acf based on event type
    @Thomas Nygards​ I couldn't find any mac_ana_ful_sub_custom_pos under the ACAR library?
  • Thomas Nygårds
    0 Thomas Nygårds over 6 years ago
    @Oskar Jonson​  That is actually expected.
    It is the name of a macro that the user can create. If will be executed at a custom macro entry point and they exist in several places in the acar code. in the actual example at the "post" step of the execution of the macro mac_ana_ful_sub.
    So if you need something custom run at such a point then you just create a macro with a specific name (eg. mac_ana_ful_sub_custom_pos) anywhere in the database (and add it to site or plugin for ease of use)!
    Look at the macro  .acar.macros.mac_ana_ful_sub to see in the file generation process when and how it is called.
    Then you will also see that the macro should take the parameters:
    assembly
    analysis_mode
    analysis_name
    simulation_type
    (all can be strings but maybe better if : model, string, string, string) Important is also to add a user entered command to it as it cannot be empty/"use macro name".
    Note that your macro, once created, will be called for all full vehicle simulations (in this case), so be sure to insert a an appropriate if statement in the macro to only do the modifications for simulations/models which needs them to be done.
    The other option is as you say to change the acf file with your cluster submission script (which I guess you mean with the --pre command) depending on the analysis type. That might be easier in some cases, but unless you want to hardcode it, you have to look up the id of the torque. This can of course be done in many ways, but if not done in adams it might require some adm text processing to be on the safe side.
    Regards
    Thomas
  • MK202610123211
    0 MK202610123211 over 6 years ago
    How about introducing a new gear like -2 and trigger upon value of gear_demand ?
    That'd add a single maninimaneuver for your parking brake where you set gear_demand to -2 and you're done.
    Another one would be to add the parking brake trigger to the brake system and donate a speed sensor.
    Algo would be like "If speed is below threshold and brake_demand is > 0, then apply parking brake" and the inserted mini-maneuver would simply be something like zero speed and brake demand set to 100.
