  2. Adams Car
  3. How can I trigger an external action from within the driver...
  • Replies 9
  • Subscribers 1
  • Views 3
How can I trigger an external action from within the driver control file?
o.jonson
o.jonson over 6 years ago
I want to trigger an action from within the driver control files that is not an standard output (throttle/steering/clutch etc). Basically I want to do some minimaneuvers to achieve a certain vehicle state, then activate a parking lock torque in the gearbox, then deactivate it and continue the simulation.
Of course I could use some STEP(time) functions in the torque expression to activate the torque at the right moment, but that solution wouldn't be general for different driver control files . Any ideas on how to trigger such an action from within the driver control file?
/Oskar
  • Thomas Nygårds
    0 Thomas Nygårds over 6 years ago
    Unfortunately you cannot do this as you would like .
    Several customers are asking for this, (in artifact ADMS-52087), and it seems like we are getting some traction on this, but do not take this as a promise!
    Unfortunately I do not think the minimaneuver_id is available as a variable either (just as a request), as that would be a nice workaround. So for now you are pretty left out with just time or other variables to change a variable or to trigger a sensor.
    Regards
    Thomas
  • r.gobbur
    0 r.gobbur over 6 years ago
    You can create torque at spindle joint and in acf you activate/deactivate based on simulation time
  • Jesper Slattengren
    0 Jesper Slattengren over 6 years ago
    @Ravichandra Gobbur​ , In ADAMS/Car do you not have access to the acf-file the same way as you do in a regular solver simulation. There is no easy way to stop/restart a run/
  • r.gobbur
    You create torque and activation/deactivation can be done by using .cmd file.
    Let me know which event you are doing.
  • Thomas Nygårds
    Actually r.gobbur has got a point.
    You could replace the EventAll with acouple of EventRunNext in the acf then insert commands to activate/deactivate the torque. Manual work, but a valid workaround.
    When thought about, it is even possible to do it automatically with the use of a mac_ana_ful_sub_custom_pos macro (but that would only work for files_only analyses).
    Regards
    Thomas
