  2. Adams Car
  3. Simulation of fmu model from Acar in Simulink
  • Replies 7
  • Subscribers 1
  • Views 478
jozef.bucha
jozef.bucha over 5 years ago
Hello everyone,
I have model of vehicle in Acar. Models works fine in Acar (no warning message,), but if i want to use it in Simulink the simulation ends with Error in supplied FMU: An error occurred in function 'fmi2ExitInitializationMode' for block.
How can I start to debug this and get more information about simulation run and what is wrong?
Produced fmu can be used without problem in Adams Realtime animation but not as fmu model in Simulink
Any recommendation about solver settings in Simulink or Adams, which could helps
Thanks for advices
Jozef
  • Fredrik Sjogren
    0 Fredrik Sjogren over 5 years ago
    Hi Jozef,
    Have you started a dedicated MATLAB session for the FMU co-simulation?
    https://se.mathworks.com/help/simulink/ug/export-model-as-tool-coupling-fmu.html
    Start dedicated MATLAB session for FMU co-simulation: From the MATLAB prompt:
    >> shareMATLABForFMUCoSim
    /Fredrik
  • Fredrik Sjogren
    The above is something you need to do when using a co-sim Simulink FMU in Adams. Reading your post again I now realize you want to run an Adams FMU in Simulink...
  • jozef.bucha
    0 jozef.bucha over 5 years ago
    Thanks, for reply
    Yes I want to do Adams FMU in Simulink
    Jozef
  • jozef.bucha
    Also i have noticed that fmu works fine for in Simulink until i am using steering subsystem not in kinematic mode but in compliant mode. If i switch steering to kinematic mode fmu stops to work. Vehicle in Adams works in both modes. Steering subsystem is based on rack_and_pinion_steering template from acar shared directory.
    Jozef
  • frieder.platte
    0 frieder.platte over 3 years ago
    Hi Jozef,
    do you have found a solution for your problem  'fmi2ExitInitializationMode'? I have the same at the moment and can´t figure out how to get rid of it.
    Frieder
